Accelerating Problem
Old Jun 24, 2004 | 09:38 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
i have the L69 305 carb,5-speed and when im taking off if i try to floor it it wont go nowhere it goes slower its like it wants to die,you have to let go off the gas and proceed slowly to rise up to speed,any thoughts i already tried changing the fuel filter Thanks
Old Jun 24, 2004 | 09:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What's the fuel pressure when it does this?
Old Jun 24, 2004 | 09:59 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
to be honest i dont know,how would i check this,i know when i bought it it already had a autometer temp,and oil gauge on the a-pillar,on the dash all that works now is the tach,Speedo(now),maybe the bat.and fuel(maybe)
Old Jun 24, 2004 | 10:00 PM
87Formula4bbl's Avatar
Car: '87 Formula
Check to make sure that when you hit the gas pedal that some gas squirts into the primary bores of the carb. Just take off your air filter to check (or top cover if using stock air box).
Old Jun 24, 2004 | 10:04 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
i was thinking it was the carb,what if it does ,then what ,also what if it dont
Old Jun 24, 2004 | 11:46 PM
Car: '87 Formula
It SHOULD squirt gas into the bores when the gas pedal is pressed.
Old Jun 24, 2004 | 11:48 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
coo ill try it tomorrow
Old Jun 24, 2004 | 11:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The only thing is, just becuase there is fuel getting squirted into the venturis of the carb, doesn't mean that the pressure is inadequate.
You know for a fact that everyting is is good to go (the standard tune up issues)?
Old Jun 25, 2004 | 12:01 AM
Car: '87 Formula
I know, just giving him something simple to check first before he goes out and buys/borrows and hooks up a pressure gauge.
Old Jun 26, 2004 | 11:14 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
well it all checks out ok,but what can be the problem
Old Jun 26, 2004 | 11:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the secondary air valve is WAY loose, or stuck wide open; or the sec rods have fallen out of the hanger.
Old Jun 26, 2004 | 11:28 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
how can i fix that
Old Jun 26, 2004 | 11:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Adjust it properly, unstick it, reassemble it correctly
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
