oil leak
Old Apr 9, 2001 | 01:26 PM
miked's Avatar
oil leak
Just want to see if there is a common leak that would act like this. It is on a 2.8L (soon to be 350). When the car is running there is a constant flow of oil coming down over the oil filter adapter and leaking onto the ground. I was thinking possibly it was the front of the oil pan, valve cover (doesn't look like it), or ?. Anyone seen something like this?
Old Apr 9, 2001 | 02:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Isn't that where the oil pressure sending unit lives? It isn't uncommon for them to leak through the body. It's been a few years, but I had one do that on a FWD 2.8.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Old Apr 9, 2001 | 03:44 PM
82camaro's Avatar
Car: 82 camaro SC
Does it have a distributer? If not, the distributer plug(where the distributer used to be on the older 60 degree v6's) is probably leaking. This is really common, and a pain to fix. All the 60 degree v6's without a dist. had a problem with it until GM decided to use a better seal. My brother-inlaws Lumina Z34 leaks a small stream from it until the engine warms up--then it drips constantly. Head removal on the 3.4 twin dual cam to replace the seal. He traded it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 9, 2001 | 04:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had the same problem and it was the same problem mentioned above. On my 3.1 Lumina it would always leak until I got he little round rubber seal from GM. Oil Pump Gear Drive Seal it was called. About 40 cents. It took me about 2 hours to do.
Old Apr 9, 2001 | 04:27 PM
miked's Avatar
It has a distributor. Someone told me that it still could be caused by this. They said I should pull out the distributor and replace a rubber o-ring. Sounds easy enough. Sound like something to consider? Thanks for the input.
Old Apr 9, 2001 | 07:01 PM
five7kid's Avatar
All 3rd gen V6's had distributors. I haven't heard of a distributor leaking unless the o-ring is completely missing. You might want to check closer above the point where it is dripping.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
