Stripped threads in aluminum intake
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I was in the final stages of getting my intake reinstalled and was torqueing down the throttle body bolts (LO3) and just as I reached the point where the torque wrench was supposed to click the tension just faded away. I pulled the TB back off and checked the offending hole and found pieces of the threads on the bolts. Can I drill the hole out and install a heli-coil at this point on an aluminum intake manifold? I've had to do it once before on the tranny case for a pan bolt with no problem but I'm not too sure about this. I don't want to have to buy a new manifold and I certainly don't want to go back with the OE piece. The intake is an older Performer TBI with the removeable torque tubes and I want to keep it.
Car: 90 Formula
Glad to hear it. I just picked up a kit and I may just do all three holes where the TB mounts to the manifold. Thanks for the assist.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
