Will this cam work okay?
Old Jun 27, 2004 | 02:00 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
After to talking with some people in the drag race forum, I was wondering if I maybe should swap out my cam. I pulled the 305 yesterday and I would like to figure this out before I put the 406 in. This is my setup right now:
406
650 cfm Holley VS carb
Chevy aluminum intake
882 heads (yes I know they are crap but new heads are $$$)
flat top pistons, 5.565" rods, stock crank
RV cam
Hedman 1 5/8" headers with 2.5" dual turbo mufflers and cutouts
I have a Comp Cams Magnum grind 280H cam (280 adv./230 @ .050", .480" lift) I know it does not match the setup as well as the RV cam does but I don't think I will be able to hook up all the torque with the RV cam plus it will drop off about 4500 or so rpms. I know better than to use Desktop Dyno to get real power numbers, but I have heard it is good for getting a good idea of the power curve and the 280H moves the torque peak up 1000 rpms and the hp peak up 500 rpms. Will it be a good idea to swap out this cam? Will the cam fit without hitting the rods? How difficult would it be to change out the valvesprings, and would there be a way to see if I need to (i.e. part number on them, way to check lift limits, etc.)?
Thanks,
Adam
Old Jun 28, 2004 | 11:50 AM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
bueller.....
Old Jun 28, 2004 | 12:11 PM
ljnowell's Avatar
I run that exact same cam in my 350, and I think its alrigt. Plenty of power and no problems. Pulls enough vacuum for power brakes, and has one mean and nasty idle.
Old Jun 28, 2004 | 12:58 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
How tough is it to change valve springs? Anybody know if the rods will have to be clearanced?
Old Jun 28, 2004 | 01:47 PM
ljnowell's Avatar
Should be no need at all to clearance anything. As for valvesprings, do a search and you will find lots of threads on replacing them.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
