comp. Magnum cams??????????
Old Apr 9, 2001 | 09:31 PM
spitfire350's Avatar
heres the deal, i have a post 87 roller block and a freind of mine just gave me a comp magnum cams 280h cam and a set of flat tappets for free still in the box. But the problem is can i put non roller lifters in a block machined for roller? and if i can would that 280h cam be to big to use with the stock valve springs?
well thanx for the help
keep the stang's far behind u and the cops even farther
Old Apr 9, 2001 | 09:40 PM
Vader's Avatar
Spit,
1. Yes. (But you'll need longer push rods);
2. Yes. (You'll need much better valve springs, and probably head machining to accomodate the springs. I wouls also recommend changing to screwed rocker studs if you haven't already done so.)
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 9, 2001 | 10:50 PM
Guest
Guest
Posts: n/a
You will need an appropriate timing chain as well, and lose the retainer plate that holds the cam in.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
