Oil on intake manifold
Old Jun 29, 2004 | 06:02 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Latley i have been noticing i have pools of oil on my intake manifold. So i thought maybe the valve covers are leaking. Nope i replaced the gaskets and didnt do anything. Im wondering if anyone else might know of another gasket that goes out on the 5.7L TPI motor that would cause this leak. In addition, just recently, i have been getting burning oil smell in the car threw the air vents. The car usually smokes on cold startups then quits, but it never has passed the smell into the car unless i had the windows down or something. Courious if anyone has any pointers at all. I just changed the oil in it and it seems to be smoking less. I went to a thicker oil and used a oil additive. Thanks!!
Matt
91 formula
5.7L TPI
700R4
Old Jun 29, 2004 | 06:52 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You sure it is oil and not coolant? Is it on the driver or pasanger side. Check the PCV, that could be sucking alot of oil into the itake.
Old Jun 29, 2004 | 07:46 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Intake gaskets may be leaking also.
Old Jun 29, 2004 | 08:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Where is the oil? Depending on the where we may be able to tell you the why. (ie at the rear of the block, distributor)
Old Jun 29, 2004 | 09:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Oil can come from your intake bolts as well. It should leave a trail to where its source is.
Old Jun 30, 2004 | 10:22 AM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Im sure its oil, it seems to be pooling up on the top of the intake manifold. Both sides at that. I thought it was the pcv also but i couldnt see anything leaking out from it directly. The oil pools basically run along both side about 2 inches in from the valve covers. Thats why i thought the valve covers were leaking. But since i did those and it still leaks i kinda got stumped. Never torn apart a intake manifold, so are these bolts that could be leaking just need to be tightened or do i need to have the intake manifold gasket replaced?
Old Jun 30, 2004 | 11:55 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Is the oil right below where the intake runners attach to the manifold? I just noticed oil there on mine, I have some major blowby happening, and oil is being fed into my plenum via the crankcase breather tube(the one that goes from the passenger side valve cover to the throttle body). I think so much oil has built up in there, when the engine gets hot it is leaking from where the runners bolt to the manifold.
Old Jun 30, 2004 | 01:42 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
YES, thats where it is. I know ihave blow by on my motor also and that the breather is putting out some oil into the intake manifold itself. Anyone know a way to fix that (aka. quick fix) w/o rebuilting the motor. The breather on it now i belive is just a hose running from the valve cover to just past the throttle body.
Old Jun 30, 2004 | 02:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely it is coming up around the threads of the manifold mount bolts. Take them out one at a time, clean, coat the threads with Teflon paste sealant, torque, move on to the next one.
Old Jul 1, 2004 | 03:50 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Some people direct the hose that goes to the throttle body into some type of container, usually with a lid they can take off and dump out the oil occassionally. I am probably going to do this same thing since I can't afford a rebuild right now, and obviously quite a bit of oil is building up in the plenum for it to be running out on the manifold. Do a search for blowby and you'll probably find some examples, I know I have seen them on here.
Old Jul 1, 2004 | 02:32 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Cool thanks for the idea, ill do a search see what i turn up
Old Jul 1, 2004 | 03:32 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Try installing an inline fuel filter in your PCV hose. Vacuum will still be able to draw through it, but the oil and residue wil get caught in the filter, preventing it from entering your intake. I run a clear Spectre filter so i can see when i need to replace it.
This is another idea, and the Spectre filters are inexpensive. But I think most of my oil is coming in through the crankcase breather hose.
Old Jul 3, 2004 | 01:53 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I know that this may be just another way to "mask" the problem, but does anyone know if taller valve covers would help. Since the oil would have to travel farther to end up in the crankcase breather hose.
Do they even make tall center bolt valve covers?
Old Jul 3, 2004 | 12:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Find some valve covers with baffles. The baffle acts as a "splash shield" and prevents the percentage of the oily gunk from getting picked up by the crankcase vent system.
Old Jul 3, 2004 | 04:19 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I am using the stock covers with the baffles on them.
Old Jul 4, 2004 | 08:38 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by 1990GTA
Some people direct the hose that goes to the throttle body into some type of container, ...
The one in the manifold. The one in the TB is the fresh air path. Air should be going into the crankcase in that tube. If you have oil in there there is a problem elsewhere.
Old Jul 5, 2004 | 02:04 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I also have this problem, could this cause blue smoke while driving. Its not much but when you press the accelerator i sometimes sends some blue smoke. I can also feel a smell of burnt oil inside the car.
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
