Need help with cam swap!!
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
I don't know if im just stupid or what, but I went to pull my cam out, and it won't come. I've never pulled a cam before, and I figured it was supposed to be a pretty easy thing to do. It pulled out about an inch and then stopped like it's caught on something. I tried turning it and wiggling it, and it won't come any further. Please help me out with this.
Thanks,
Adam
Thanks,
Adam
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Assuming this is in the LG4 in your sig, did you unbolt the fuel pump and let the fuel pump pushrod fall out? I am willing to bet that is your problem.
Car: 1985 Z28
Engine: 383
I didn't even think about the fuel pump pushrod. It is not the LG4, it is the 406 that I am swapping the cam out of. Either way, they both have mechanical fuel pumps. Thanks a lot Stekman. TGO comes to my rescue once again!
Adam
