Runnin' on 3/4 quart of oil?
Old Apr 8, 2001 | 12:49 PM
JETHROIROC's Avatar
My friend came over the other day so we could use my ramps to change the oil in his 300ZX, and when we pulled the drain plug only 3/4 of a quart came out, black as the ace of spades.
The oil he had in it was Mobil 1. My question is, knowing that the car has a 3 5/8 quart oil capacity, would the engine have seized up running with only 3/4 quart if it hadn't been synthetic? I was just curious.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Apr 8, 2001 | 01:42 PM
Synergy's Avatar
Probably...
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Apr 8, 2001 | 02:00 PM
ede's Avatar
ede
i doubt it
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 8, 2001 | 07:41 PM
82camaro's Avatar
Car: 82 camaro SC
The filter probably had some oil in it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 8, 2001 | 07:49 PM
JETHROIROC's Avatar
I was including that in the 3/4 total. No biggie, I was just curious. Thanks for the responses guys.
Old Apr 9, 2001 | 10:02 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
If your friend drove around town real slow, and didn't rev the motor, then enough oil might have fallen back to the pan fast enough to keep up pressure. If he revved it though, his 3/4 quart of oil might end up all up top, with the oil pump trying to pump air.
Same goes with hard acceleration,turning, or braking. If the oil sloshed away from the pickup, then the oil pressue light should have turned on.
Old Apr 9, 2001 | 12:47 PM
a73camaro's Avatar
You should teach your friend how to check the oil level.
Old Apr 10, 2001 | 03:47 PM
Eddie's Avatar
My car never burned a drop of oil and every time I checked it it was doing fine then one day while changing the oil I only drained about 1 quart mind you the car ran just as it always had but a few months later it started smoking due to blow-by mostly and some being valve seals but to make the story short....wouldn't have siezed but his engine is probably shot and it won't be long till it shows, only thing going for him is the mobil 1 hopefully he is lucky.
Old Apr 10, 2001 | 07:04 PM
JETHROIROC's Avatar
That's what I figured. He's got some serious tapping noises going on in it already and he flogs the hell out of it all the time. It's not that old (80,000 miles) but I wouldn't be suprised to see it bite the dust sometime in the near future. We put Mobil 1 back in, so perhaps the car can drink from the water of life if he keeps tabs on the oil level regularly. In reality, he'd be better off with an IROC, but since the car was given to him I guess I can make an exception. Thanks for the input guys and I'll be sure to beat the **** out of him the next time he thinks the dipstick is wrong!
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
abray1
Sep 14, 2015 08:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
