416 heads on a 350 block? yea or nay
Old Jun 30, 2004 | 11:49 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
I got a set of 416 heads off a 305, following the port and polish article on here, would they work on a 350 to increase compression or would it be a waste of time, and a other wise stock L98?
Old Jun 30, 2004 | 12:03 PM
Xceleratemaro's Avatar
EDIT- i was not aware that 416 heads had 165 cc.. but if you have um laying around y not. sorry.. i have had bad ex with 305 heads on 350's
Old Jun 30, 2004 | 12:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
yes you would boost comprestion but lose flow.. so i wouldnt do it.. the runner are smaller on the 305 heads. there for less low end power!
That is a fairy tale, the 416 heads have a 165cc intake runner, that is bigger then most 350 heads. This guy obviously doesn't know what he is talking about, a smaller runner will give you more low end power, due to the increased velocity.
Old Jun 30, 2004 | 12:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Thats what i had always thought.
Smaller runner = more low end, at the expense of top end support
bigger runner =more top end, at the expense of low end velocity
I have 416s that ive massaged out a tad. on my engine. They work fine. They benifit from 350 sized valves, however. 1.94/1.6 are what i used. used Sitting Bulls thread as a guideline. i was pleased with the results...granted i am yet to run with them.
I say go for it.
Old Jun 30, 2004 | 01:13 PM
Car: 1987 Trans Am
Engine: tree-fiddy
ok well it will be a while before i put them on, as I just got the car running fine, and i have no money to get the valve train for them? thou i have a dremel and some grinding wheels so i will give it a go.
Old Jun 30, 2004 | 01:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You will want carbide cutters. I'm sure grinding wheels would work, but time isn't going to stop and wait.
I have a dremel, but opted to use a die grinder with variable speed control. I was glad i did. At that, i prefer the 1/4" shank of the die grinder over the 1/8" of the dremel. Also, i have never seen a 6" carbide of any tip shape, with a 1/8" shank diameter. And those 6" cutters work really nice for the deep port work.
Old Jun 30, 2004 | 02:25 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Your not going to get anywhere fast with a dremel.
Old Jun 30, 2004 | 06:36 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Mine worked dynamite. good power to 7000rpm, fully ported with 1.94 x1.60 valves.
I got a little carried away with the compression ratio.
It was 12.65:1. Make yours around 10:1.
Good go for the $doe$.
Got to ask thou, Y not just soup up the L-98 heads?
Old Jun 30, 2004 | 08:53 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Hey Russ,
Have you gotten through the quarter yet this year with the 416s on your 350? I know your engine grenaded last year and am wondering if you have a current ET?
Old Jun 30, 2004 | 10:13 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Someone help me out here. Wouldnt #416s have different intake bolt angles than #083 TPI heads?
Old Jun 30, 2004 | 10:15 PM
F-BIRD'88's Avatar
Originally posted by Sitting Bull
Hey Russ,
No I haven't. Been too busy working, and playing with the new 406. the 350 is on the engine stand and will be coming apart soon. may need a sleeve.
one head was destroyed. But would like to get it back together again. was a blast to drive. easy 12's.
May slide the 350 into somthing real light like a 79-84 RX7 with a lil NOS.... Can u say 10's for $2000?
looking for one of these.....and 1 more Cheater NOS plate
Old Jun 30, 2004 | 10:28 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Thats funny, look what I actually found tonight looking for some parts I had in the closet...lol
Email me Ill get rid of it soleniods and all pretty cheap. Off of a Cheater system
Old Jun 30, 2004 | 10:36 PM
F-BIRD'88's Avatar
:lala: B-E-A-U -D-E-E !!!
Just what I need for my 1 run fun project RX-7 from HELLLLL!.
Old Jul 1, 2004 | 11:02 AM
Car: 1987 Trans Am
Engine: tree-fiddy
Because i need the car to drive to work and back, and if my porting skills suck, i don't want to screw up the l98 heads.
Old Jul 1, 2004 | 11:27 AM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
Hi everyone...in relation with this topic....i just want to know if my 87 305 LG4 head were the same as the 80-86 #416 head....i know that my head is the same as the 305 TPI engine.
Old Jul 1, 2004 | 03:06 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No, your heads are almost the same but have center bolt valve covers. Other then that they are about the same.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Randomtask2
Aug 21, 2015 10:54 AM
BBSDesigns
Aug 11, 2015 07:39 PM
