is this ok?
Old Jun 30, 2004 | 05:12 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
is this ok?
i just wanna know if this is normal or not please. at the moment the engine starts after being off all night some smoke will come out the exhaust. it lasts for like half a second then completly stop, basicaly its 1 puff off smoke. ithink its normal but i just wanna make sure. (i have no smog stuff, car is cabed with mods<sig> 3"exhause with no cat)
thanks
Old Jun 30, 2004 | 05:18 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
What color is the smoke?
Old Jun 30, 2004 | 05:36 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds like valve seals to me should be fine but you will want to change em out eventually
Old Jun 30, 2004 | 10:31 PM
Car: 1983 Z28
Transmission: TH350
u mean the valve cover gasket?? i do need to replace the gaskets becasue one of them is leaking oil. the smoke colour is gray? how does the whole colour thing work again?? (each colour meaning?)
Old Jun 30, 2004 | 10:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No the valve seals. They seal the valve from the valve guide and combustion chamber/runner. They are under the valves springs, actually inside on the valve guide boss.
Old Jul 1, 2004 | 01:06 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Grey smoke? Would that most likely by condensed water in the exhaust pipe cooking off as steam??? I don't think burned oil would be that color, would be darker.
Old Jul 1, 2004 | 03:22 PM
Car: 1983 Z28
Transmission: TH350
oh lol my bad, but ya the colour is a light gray. i also figured it was "condensed water in the exhaust pipe" cuz it only does one puff and only does it the second the car starts after sitting all night. if i have it off for acouple hours or more theres no smoke when start up, only in the morning.
i managed to find most of the colour meaning except blue what does blueish colour smoke mean?
Old Jul 1, 2004 | 03:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Blue smoke means oil is finding it's way to the combustion chamber. For small chevies, the most common thing is the valve seal. But, of course, there are other ways for oil to get to the chamber.
