starter troubles ?
Old Jul 1, 2004 | 01:13 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
starter troubles ?
i have some headman headers and i have a full fiberglass blanket on the starter, when i drive it for a long time and shut it off, when i go to start it shortly after it turns over and stops, and does this over and over, let it sit and it starts up after a while, what is causing this? the starter is fairly new i changed it because of this before, what can i do to resolve this? also after it turns over and stops when i get it started the temp gauge doesnt seem to work anymore until it sits
Old Jul 1, 2004 | 01:15 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
The starter can't handle the heat.
Old Jul 1, 2004 | 04:08 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
is the heatsheild physically touching the header? could be transfering too much heat.. it sounds like its getting heatsoaked.. is this a factory starter? You might try a mini starter like the lt1 starter.. I switched over when I had similiar problems with my factory starter.. you could also try wiring in a ford starter solenoid.
Old Jul 1, 2004 | 04:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What starter motor is this? A mini-starter is the ideal fix for people with LT headers.
On a side note, the factory starter isn't known for its cranking power.
Old Jul 1, 2004 | 05:11 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah it's an oem starter for the 305, i have shorty headers on it, gonna try an LT1 starter
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
