Putting on the heads....
Old Jun 30, 2004 | 12:11 PM
bigals87z28's Avatar
Car: Check The Sig
I wanted to know if I should put a little blue RTV sealant on the gasket, and if I should, where?
Old Jun 30, 2004 | 12:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The Fel-Pro's that i use (standard .039") do not require RTV or any such material.
I personally have never used any.
Old Jun 30, 2004 | 01:15 PM
ede's Avatar
ede
i use copper spray from kw on head gaskets. doubt i really need it but also never had one leak.
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
