What is knock retard and why does it take away so much power
basically the knock senser tells when you have knock and the est (eletric spark timing) changes the timing to eliminate the knock. this change in timing may not be the best setting for preformance.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
it's supposed to be a safeguard so you don't blow the motor with detonation (too lean, bad fuel etc..).
Knock sensor (like a microphone) listens for knock then tells your ecu. Then it takes away timing.
TPI motors get too much false retard. Can be caused by roller rockers...headers..tc
I plan to disconnect mine and see if I notice a difference.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
305 TPI 5speed
1LE/G92/WS6
sailtexas186548
Aug 24, 2015 10:11 PM
