305 to 350 power add?
Old Jun 30, 2004 | 01:22 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
Does any of you have any experience of swapping from 305 tbi to 350 tbi whith the same mods.
I am looking for a nice driveable 350tbi whith these mods:Ported 305 tpi heads, LT1 cam-95,670 cfm tbi.edelbroc performer intake bored to 2",Headders,3" full flow exhaust,custom chip.
I am a little disapointed of my 305 today.
Please feel free to replay if you have any comments of this swap.
I am also thinking of selling my cab for a lighter Iroc ,that heavy cab eats hp to no good.
Old Jun 30, 2004 | 01:24 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Sorry forget to tell you that my goal on that new 350 is about 300HP.
Old Jun 30, 2004 | 03:14 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I switched over from a 305 TBI to 350 TBI.......the difference was night and day. Then went from TBI to TPI and the difference was night and day again. Only problem is now the car just wants to sit and spin off the tires But all in all i'de never go back to a 305 nor TBI. Nothing wrong with either one of them, just doesn't have the HP or torque.
Old Jun 30, 2004 | 03:48 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Yeah the 305 tbi to 350 swap was a pretty big change. I had a few problems getting my 350 tbi to run right but it was worth it once it was running. With that setup you should see 300hp at the fly as long as you have a good tune. Good Luck.
Old Jul 1, 2004 | 01:28 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
Thaks
I dont want to spend any more money on that 305 if it like you say,I will go for a 350 TBI becose these engines are wery cheap here in sweden. What should i do to that engine to get to the 300hp range,heads and cam or just tuning whith intake and exhaust?
Old Jul 1, 2004 | 02:19 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Youll need a good set of heads and a decent sized cam. performence intake, throttle body, and exhaust to reach 300hp plus tuning. The ported 305 tpi heads and lt1 cam combo sounds good. Good Luck.
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
