58cc heads, what compression ratio?
Old Apr 10, 2001 | 09:19 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I'm considering buying a set of 58cc heads, but what will that put my compression ratio at in an L98? I'll be using Summit's rebuild kit with new pistons, if that makes a difference.
Old Apr 10, 2001 | 09:46 PM
steve8586iroc's Avatar
I would say in the 10.0/1 range maybe more depending on the pistons you get. What type of head will you be using, iron or aluminum?
Steve
Old Apr 10, 2001 | 10:16 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
They're aluminum. I may get them milled a little, and the block decked too if I have enough metal to shave off. I don't want the compression ratio over 10.5.
Old Apr 10, 2001 | 10:48 PM
Guest
Guest
Posts: n/a
Find out what the cc of the pistons are before you cut anything. Thats pretty important at this point.
Old Apr 10, 2001 | 11:20 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Weren't the vettes with the L98 aluminum 58cc heads at about 9.8:1 compression? If so, that should be where your at.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
