arching on valve cover...HELP!!!!!
Old Jun 30, 2004 | 10:41 PM
25THRSS's Avatar
arcing on valve cover...HELP!!!!!
I just got done putting the LS1 back together and now there is arching going on between the passenger side valve cover and the head. I thought it might be the coil which was arccing earlier too, but I replaced that and it is still there. What could it possibly be, a bad ground???? I'm lost, please help me here.
Old Jun 30, 2004 | 10:46 PM
AM Racer's Avatar
If it's arcing as in high voltage, then there's a bad wire or plug.
Electricity takes the shortest path to ground.
Old Jul 1, 2004 | 12:22 AM
25THRSS's Avatar
It's not arching out of the plug though, it's arching from the actual head to an accessory bracket.
Old Jul 1, 2004 | 12:27 AM
vampiroc's Avatar
Car: Z28
when the boot on my alternator wire (the hot wire) rotted away it was arcing onto the valve cover, that could be a possible source.
AM Racer's Avatar
Spray water on the wires in the dark and move them around.
Maybe you put a slit in one or pinched it.
Old Jul 1, 2004 | 12:30 AM
25THRSS's Avatar
What would spraying water do?
Old Jul 1, 2004 | 12:34 AM
vampiroc's Avatar
Car: Z28
nothing that I can think of. if its arcing, you can see it in the dark just fine. in fact putting water around the area could make it harder to find if the water is closer to the short than where its arcing
Old Jul 1, 2004 | 12:37 AM
25THRSS's Avatar
What I don't get though is why it's arching from the head to the accessory bracket, and I see no arching at all from any of the spark plug wires. Also if it matters it is also arching in another spot further back on the engine that I can not see real well.
Old Jul 1, 2004 | 01:31 AM
vampiroc's Avatar
Car: Z28
I just say follow the sparks. if it's arcing from another place behind the engine that means its gotta be running through the there but not grounding out for some reason
Old Jul 1, 2004 | 01:50 AM
25THRSS's Avatar
I'm starting to think I got a set of bad plug wires?
Old Jul 1, 2004 | 02:00 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The fact that there are sizable arcs between the head and accesory bracket is really wierd... The head should be pretty much as grounded in the car as you can get unless there isnt a good ground going from the engine to the battery.
Old Jul 1, 2004 | 07:00 PM
25THRSS's Avatar
Well I feel so stupid now! Relieved at the same time too. The very rear passenger side spark plug wire had fallen off and since it's so crowded I couldn't even see that it had fallen off and was causing the arcing. Thing runs like a raped ape again! I love having over 500 hp at the blip of the throttle.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
