Can I run 1.6 roller tip rockers on the 305??
Old Jul 1, 2004 | 10:08 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
I have a 305 Z28 and I want to know if I can run the Comp cams magunim 1.6 roller tip rockers. I have stock 305 heads with Crane single coil springs and a crane 272 H10 cam .454 lift 272 dur. Or will I have to modd the heads so the retainers wont hit??
Old Jul 1, 2004 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You will be fine, no modifications will be needed.
Old Jul 1, 2004 | 10:32 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
You SHOULD be fine, but check the clearance around the pushrods to be sure. Comp cams recomends this even if it's a stock application.
Old Jul 1, 2004 | 10:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Wait, what valve springs are you using now?
Old Jul 1, 2004 | 10:42 PM
91305z's Avatar
they will work just fine. I have the same ones on my car for 15k and haven't had a single problem. they fit just fine
Old Jul 1, 2004 | 11:02 PM
laiky's Avatar
regardless of what people say here you must check the clearance between the pushrods and the slotted holes in the heads. I needed to elongate mine. CC sells a tool for this but it involves using a dril to open the slots up. so clean up is critical. you will probably need to remove the intake to avoid contaminating your engine. Also when your checking clearance, rotate the engine through at least 2 revolutions don't just eyeball it.
Old Jul 1, 2004 | 11:28 PM
Car: 83 Z28
Like the man said.
If you check it then you KNOW it will work.
Old Mar 5, 2011 | 09:39 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: Can I run 1.6 roller tip rockers on the 305??
Yes a old thread,but, what wasnt said here is that not all roller tip rockers are not the same AT ALL. some are self alinging and some are not. You need to DOUBLE check the tops of the valves to make sure you dont screw the pooch and have a valve fall into the cylinder.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reborn756
Sep 4, 2015 03:42 AM
happyhapka
Aug 15, 2015 04:42 PM
BrianI
Aug 9, 2015 11:52 AM
