Erratic oil pressure gauge
Old Apr 9, 2001 | 02:14 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
When i turn the ignition on, the gauge jumps around. It normal when the engine is on though. What is going on?
  • 89 Formula 305 WS6
    SFC's
    LCA's
    Spohn Panhard Bar
    Air Foil
    Flowmaster Cat Back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? HA! Its A Rice Burner!
Old Apr 9, 2001 | 04:47 PM
ede's Avatar
ede
usually oil preasure is related to engine speed, more rpm = more oil preasure. if you're unsure about it first thing i'd do is put a mechanical gauge on the engine and see what you have.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 9, 2001 | 06:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The easiest thing to do is just swap the sending unit... that sounds like what's wrong. It's about $15 and takes about 3 minutes to change.
ICON Motorsports
Old Apr 11, 2001 | 08:44 AM
Omega's Avatar
Engine: LS1 / LS3
Cool, thanks. I have never seen it fluctuate before. I will end up changing the sending unit, i just was wondering if it was a normal occurance when the engine is off
Old Apr 11, 2001 | 10:05 AM
Steve89GTA's Avatar
Mine did this for a couple of months and then just stopped out of the blue. It's been fine now for a year....weird
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
