ZZ3 head cleaning
Old Jul 5, 2004 | 08:37 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
ZZ3 head cleaning
I am in the process of transferring my ZZ3 aluminum heads from my 305 to a 350. What is the best method to clean the head gasket material off without damaging the aluminum? I used the GM head gasket that was designed for this head, and I'm glad I did. I can very easily remove the composite gasket material with a finger nail, but I'm sure there must be a better way... What is it?
Thanks.
Old Jul 5, 2004 | 12:12 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: ZZ3 head cleaning
Thanks.
There is an attachment for your drill that looks sort of like a roundwire brush (2 or 3" in diameter and often light green) but it is made of a very hard rubber/plastic compound. It should be available at any well stocked auto shop.
Old Jul 5, 2004 | 06:22 PM
Engine: 5.7L TPI
I think this is what I need to find... is this sort of what you had in mind sitting bull?
http://www.tapecase.com/tc/3m/asp/bristle.asp
Old Jul 5, 2004 | 10:07 PM
Engine: 305-4v
That be them.
Old Jul 5, 2004 | 10:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A new, sharp razor blade works wonders.
Old Jul 5, 2004 | 10:57 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yeah i always use a razor blade, but the drill attachment is much more thorough and alot quicker.
deracer
Apr 11, 2016 12:04 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
