something leaking in side car ??
Old Apr 11, 2001 | 11:38 AM
Todds1987iroc's Avatar
I think I might have a heater core that is leaking. Anyone change one out? Do you have to take the hole dash apart? This morning when I got into work the passanger floor mat and carpet were all wet and smelled like antifreze. Is there any other hose in there that might leak. Please tell how pist a going to get upon try to replace it.
1987 Camaro IROC-Z w/ 305 tpi/5-speed/9 bolt 3.45 gear
1969 Camaro with '96 350 vortec truck engine
Old Apr 11, 2001 | 12:15 PM
burnoutrpm's Avatar
yes the heater core flew south. the next step is to take apart the entire dash to get to the core then undo the hoses at the fire wall under the hood and then inside you have to take a plastic cover off the core itslef and then your looking right at the annoying piece just take it out ...and remember!...instalation is the reverse of teardown!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 11, 2001 | 12:42 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
dont jump the gun! couple months ago i thought my heater core blew, so i commenced to tearing the dash apart. what a mistake. the hose clamp had loosened up on one of the hoses at the firewall. once the engine warmed up coolant system pressure built up and it sprayed into the car. man i was pi$$ed off. its a lot of work getting that heater core out.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 11, 2001 | 04:36 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
You don't have to take the whole dash apart, just the underside (hush panel, and ducting) Then w/ nimble hands you can pull the old one out and put the new ones in. I have large hands, and large forearms and managed this...although I didn't put the ducting back exactly as it should have been since the previous dumb@$$ cracked alot of it...eventually when I have $$$ I'll go back and fix it properly
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
I really think it is the heater core. I was leaking a very small amount about a year and a half ago and I put Stop Leak in and it worked. Does anyone now how much a new one costs?
1987 Camaro IROC-Z w/ 305 tpi/5-speed/9 bolt 3.45 gear/L98 Corvette heads/ T.E.S. headers/ LT4 production cam/ 1.6 rockers/ Flowmaster exhaust.
1969 Camaro with '96 350 vortec truck engine w/ mods
Old Apr 12, 2001 | 12:36 AM
Corry's Avatar
Car: 1987 Trans Am
I don't remember clearly, but I think it was $20-$30. It's just a tiny radiator, cant be much.
Corry Lazarowitz
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
