Can someone tell me step by step how to install new rockers?
Old Apr 11, 2001 | 08:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I got the Comp Pro Mags. I didnt get the full roller ones, cause I got these cheap. Thanks its on a 350 TPI
Old Apr 12, 2001 | 12:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remove whatever is in the way of removing the valve covers, then remove the valve covers.
Unscrew the 1st rocker, remove rocker, ball, & nut. Oil up and install new rocker, ball & nut (this would be a good time for new push rods), tighten approximately to point of removed rocker. Repeat for remaining 15.
Adjust the rockers by the book. I'd repeat what the book says, but I'm about 656 miles away from my book right now.
Clean old gasket from valve covers & heads, install new gaskets, replace covers and whatever you removed to get to them.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited April 11, 2001).]
sweet_87_iroc
Sep 25, 2015 10:01 PM
crazynights
Aug 21, 2015 06:53 AM
Cameeeero
Aug 20, 2015 03:06 AM
IrocZ'85
Aug 17, 2015 06:24 PM
