whew! many troubles with the MAT. help?
Old Jul 5, 2004 | 10:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok so i installed my edelbrock performer TBI today.. and after all troubles.. yes the rear china wall leaks oill.. badly.. ok so i get to pull that off in a few minutes to redo it all..
but also driving around today to test it.. i get an SES light.. so i take reading and i get codes 22,25,33,42 . 22 is MAT temp lo, 25 is MAT temp hi, 33 is MAP volts hi/vac lo and 42 is the EST.
can someone tell me what is going on here?
Old Jul 5, 2004 | 10:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you re-connect everything correctly? Sounds like you have some stuff crossed or left un-hooked. Did you plug the MAP back into the rear of the TBI unit? Did you set the timing correctly?
Old Jul 5, 2004 | 10:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: whew! many troubles with the MAT. help?
I believe that you are slightly mistaken with code 22 there. It really means Throttle Position (TPS) Sensor circuit (Signal Voltage Low). Code 23 means MAT Temp (Low Temp Indicated) and I don't really believe that you will have code 23 & 25 both flashing at the same time.
Old Jul 5, 2004 | 10:57 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
you are correct, it is codes 23, 25, 33, 42.
and yes i got all 4 today at once..
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
