1.6 rockers
Old Jul 5, 2004 | 11:20 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
1.6 rockers
how much lift could i gain on a stock lo3 peanut cam with 1.6 rockers? would i need stronger valve springs?
Old Jul 5, 2004 | 11:23 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
.30 more.
Old Jul 5, 2004 | 11:28 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
so should i get strong springs?
Old Jul 5, 2004 | 11:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
you CAN, you don't have to, though. The lift on the peanut cam is small enough that even with 1.6 rockers you dont max out the springs.
the peanut cam is .350/.384" lift with 1.5 rockers. With 1.6 it's .373/.410" lift. If you do upgrade, a simple spring like the 981 would probably work ok. They may or may not require work to the valve guide, however.
Old Jul 5, 2004 | 11:59 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
do you think it would make any noticable change or a change in the exhaust tone?
Old Jul 6, 2004 | 12:09 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Nope. Power, you will gain something. Doubt you will see anything on the sound.
Old Jul 6, 2004 | 12:10 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
cool, thanks guys
Old Jul 6, 2004 | 12:28 AM
Wezzeles's Avatar
Car: Camaro
which 1.6 rockers could you get for a 92 lo3? is there a difference since its after 87 and such.
Old Jul 6, 2004 | 12:33 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
get self aligning.
http://www.jegs.com/cgi-bin/ncommerc...27&prmenbr=361
these are what i had in mind for my 89 lo3.
really not much difference from which brand. i chose these to make it easier when it comes to smog. i can show paperwork for all my mods.. except my tpi headers saying i lost that paper and they will hopefully believe me
edit: might i add, get the 3/8" studed ones
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
self aligning is what you will need. Some of the best budget pieces i have seen are the ones offered by Comp Cams; their Magnum line (steel roller tip). They are available in all versions. Both 1.5 or 1.6, in either self aligning or non.
Old Jul 6, 2004 | 10:02 AM
Wezzeles's Avatar
Car: Camaro
thanks for the information guys
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
