Use Hand Pump as a Vacuum Guage ??
Old Apr 11, 2001 | 09:58 AM
GTA88's Avatar
I want to buy a hand vacuum pump and also a vacuum guage. These things aren't as cheap as I thought they would be.
I noticed the hand pump has a vacuum guage on it. It's the pump with the reservoir attached to it for bleeding brakes. Is there some way I can make this or some other hand pump double as a vacuum guage, so I can use it to create a certain vacuum, and also to measure existing vacuum at vac hoses ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Apr 11, 2001 | 10:30 PM
Vader's Avatar
GTA,
Yes. Just close the "dump" valve on teh vacuum pump and connect the vacuum source to the fitting on the pump. You should read whatever vacuum is applied to the hose.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 12, 2001 | 10:15 AM
GTA88's Avatar
Cool. Thanks, Vader.
Old Apr 12, 2001 | 11:00 AM
Da91Bird's Avatar
Huh, huh, you said "hand pump"!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
