Starting problem, fuel tank pressure?
Old Jul 7, 2004 | 09:28 PM
Silki88GTA's Avatar
This is my first post here so please bear with me:
I have a:
1988 Pontiac GTA Notchback
5.7L 350 TPI
All stock
The starting problem I am getting is after the car sits a bit, time vaires, I will attempt to start the car and the engine turns over but it seems no fuel is getting to the engine. I then go and take the gas cap off, replace, and then the car will start right up. I did replace the fuel filter, fuel pump, water pump and radiator this year. Not sure what is causing this problem and any help would be great.
Old Jul 8, 2004 | 06:07 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Have you tried cranking it a couple times? Pressure in the tank is not uncommon and shouldnt cause your engine not to start. You may just be loosing your residule fuel pressure in the rail.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
