what would cause a car to miss an backfire?
Old Apr 12, 2001 | 08:49 PM
Kandied91z's Avatar
I found a burnt sparkplug wire and my car has begun to run ruff.
I replaced my burnt wire with a new one, but it still seemes to run ruff, mind you after a mile of driving it clears up; (probably from storage), but the next day it starts again please help with some ideas?
Old Apr 12, 2001 | 08:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I had the same problem, my car backfired and ran crappy, it was a plug that was on a header, I you sure there aren't any other bad wires.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 12, 2001 | 08:54 PM
Car: 99 Formula
Axle/Gears: 342
About it running fine after a mile, I had the same dilemma, it seemed once the car warmed up the backfire went away.
Old Apr 12, 2001 | 08:56 PM
leirch's Avatar
Did you try to pull the spark plug out(the one that had the burnt wire on it)? Maybe it got fouled out?
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Apr 12, 2001 | 09:43 PM
Kandied91z's Avatar
I'm almost certain you guys are right, i just wanted to double check before i tried this........thanks for the help guys
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
