Prom bruning and software development???
Old Apr 13, 2001 | 03:21 AM
Slow Iroc's Avatar
What are the requirements for a prom burner to be considered good enough for burning 86-93 Eproms? Any good websites you can think of (I want to do this cheap if possible.) What size Proms do we use, and how many pins?
Also, where do I find the software for it and what's the cost?
Lastly, how difficult is this? I'm talking about a MAF car here. Could you just basicly copy the old prom, save all the fuel tables, and MAF/O2 tables, and then just modify the torque curve? Also, can you increase the amount of fuel that gets in the motor by the chip?
Old Apr 13, 2001 | 05:59 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Have you tried the DIY PROM board and read Traxion's PROM Burning article (with a link at the very top of the DIY PROM board)? Tim's article has ALL the answers to all of your questions (plus a lot more). Plus, read some of the older posts (set the date to all posts over the last year) as there were a lot of "how do I start" questions in the beginning...we tend not to answer those anymore ... just point people where to read...too much re-typing.
Also, read some of the newer posts, especially about "Flash Proms". This is a recent development and us SD guys are using those now instead of the regualar eproms. They cost only a few pennies more, last virtually indefinitely AND you don't need a UV Eraser for them (saves some money).
Just don't start a "Superram vs Miniram" debate on the DIY PROM board. But, in all fairness, I think this is a reason a lot of Superram owners do not attain the potential they SHOULD. The Superram needs a special eprom to match its power characteristics, especially with Speed Density. A lot of the "custom prom writers" know how to write an eprom for TPI, modified TPI and Minirams, but not the Superram. I cannot see how a Superram could perform optimally WITHOUT an eprom designed for it.
I never pointed this out in the great "Superram vs Miniram" debate, but running either system without an eprom matched specifically to the system greatly affects the performance. If I had an eprom designed for the Superram and then installed a Miniram, the Miniram will not perform optimally. Similarly, if I had an eprom designed for the Miniram and installed a Superram, the Superram would not perform optimally.
That is why an eprom is so important, especially if you plan to run a Superram due to its unique power characteristics. A TPI eprom or Miniram eprom will defintely not make the Superram perform optimally.
Old Apr 13, 2001 | 06:19 AM
ede's Avatar
ede
i'll move this to the prom board. you should get more help there.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
