Oil leaking from tail pipes
Old Jul 12, 2004 | 02:55 AM
Acidtalons's Avatar
Having a problem with a recently built motor.
It is burning some white smoke and is leaking oil from the tail pipes.
Any ideas on what might cause this problem?
Old Jul 12, 2004 | 03:01 AM
SchwarzCamaroRS's Avatar
guess #1 would be piston rings... if it is a white/blue smoke, then your engine is burning oil and your rings are... to be nice.. shot...
Old Jul 13, 2004 | 09:29 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
White smoke is usually water/coolant. Are you getting liquid oil out of your exhaust?
Old Jul 13, 2004 | 11:22 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you verified that it is oil and not condensation?
Old Jul 13, 2004 | 04:35 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
If it is oil leaking and it is white smoke, then you quite possibly have a blown head gasket dumping oil/coolant into a cylinder. Make sure the crap coming out the tail pipe is oil though and not just water that picked up carbon from the entire exhaust system (I know if you spray water into your intake when running the car, black liquid will come out the tail pipe and its just water picking up carbon in the exhaust)..
Old Jul 13, 2004 | 04:42 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
could also be an intake gasket. my recently built motor (now rebuilding AGAIN). had the saem problem. i didnt replace the rings and head gaskets and thats why mine was smoking. my head gaskets were shot
downsouthboy
Aug 29, 2015 11:29 AM
TheExaminer
Aug 26, 2015 04:59 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
