I lost some throttle response and would like it back.
Old Apr 14, 2001 | 08:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I installed new valve seals to cure my start up smoking problem, and after getting the valves adjusted, it seems I don't have the same amount of power that I used to. Did I do something wrong? I adjusted the valves while the engine was running, backed the rockers off til I heard clicking, then went @ 5/8 - 3/4 turn. It runs real smooth, but lost something. Anybody have a suggestion? Thanks..
Old Apr 14, 2001 | 09:03 PM
ede's Avatar
ede
the rocker adjustment shouldn't hurt your power, but there isn't much else you changed except the rocker adjustment. it sounds like you got it right, i usually only go 1/2 turn. guess you could run the valves again and see if it makes any differance.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
rsrookie
Sep 5, 2015 07:08 PM
