New owner - cheesy, inexperience problem
Old Jul 12, 2004 | 09:29 PM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
Just got my first F-body ('89 GTA) and I love it. I have not had a car in years (mostly 4WD vehicles over the last 6 years) and I have never had a car this low. Naturally, it didn't take too long to come upon my first issue - how the hell do I get to the oil drain plug . Basically, I have a set of 6-Ton Jack stands that I am sure are just too tall at their lowest setting to get the car up. So I could go for lower ones (like a set of 2-ton ones). So what I am thinking is that I will just put the car on 2 ton jack stands with the rear stands slightly higher than the fronts (the oil pan has the drain plug at the front). However, that still leads to another problem - jacking the car up. It looks like wherever I put the jack, the side opposite is going to crunch the ground (i haven't tried anything yet though). Also, I can't really find the frame of the car with the ground effects in the way. Of course, I may have just missed it as by the time I decided to jack up the car I was aready annoyed with the scenario and didn't put much thought into it after that. Anyway, any tips will help keep me from breaking anything on a pretty good car.
Thanks!
Old Jul 12, 2004 | 09:35 PM
ljnowell's Avatar
Slide a small floor jack under the crossmember, and lift the car. Put a small set of jackstands (2 ton) under each side, chock the rear wheels for safety, and climb under and change the oil. Easy as that.
Old Jul 12, 2004 | 09:37 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
There is not frame to jack on. Jack on the from engine crossmember, cradle, and the rear differential case.
Old Jul 12, 2004 | 11:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you cannot get the jack under the ground effects than drive the car up on a couple of 2x4's and procede as Mr Leigh and ljnowell outlined.
Old Jul 13, 2004 | 01:08 PM
That's the answer I was looking for. Guess I really will have to buy 2-ton stands.
Thanks everyone.
Old Jul 13, 2004 | 01:41 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I thought I might include this just in case you were wondering where to place your jackstands once you got it jacked up.
Props to Vader for the picture.
Old Jul 14, 2004 | 01:35 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Invest in ramps... they are fairly cheap and make life easy with these cars. You can even get extensions for them if the car is REALLY low
Old Jul 14, 2004 | 04:03 AM
GatotsuZeroshiki's Avatar
Car: 2001 Z28 / 1986 T/A
Engine: LS1 / LG4
Transmission: 4L60E / T5
I might add that I had a set of those erector set-looking ramps collapse once -- not on me, thankfully, but they were all bent up and looked really scary. Definitely look into a set of Rhino Ramps.
Old Jul 14, 2004 | 08:04 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I have troubles with ramps (even the rhino ones). The nose just sticks out to far and hits the ramp before the tire gets to it. That is the only thing that I hate about lowered 3rd gens.
Old Jul 14, 2004 | 08:20 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I built some ramps from plywood and 2x4's. They hold trucks, vans, and my car.
Made them long and gently sloping so as to alow for low vehicles to ride up them.
Been using them for years, never had a problem.
:lala:
Old Jul 14, 2004 | 09:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That diagram shows a "stand point" under the stabilizer bar bushings; I've seen more than one car with those collapsed from doing that.
Best thing is 4 of pieces of 2x8 to drive the car up onto, arranged like a couple of stairs on each side; floor jack under the center of the K-member, being careful not to let it contact either the exhaust or the steering center link; then the stands under the ends of the K-member or the control arm bushings, immediately to the sides of where the floor jack will be.
I also have trouble with the ramps. The front ground effects hits them, and if they're on a slick surface like a garage floor, they slide when I try to drive the car up on them. They have to be on relatively rough pavement in order to work. Plus, once you get the car up on them, now you have this big thing right behind the front wheels, right exactly where you need to be able to crawl under there yourself.
Old Jul 14, 2004 | 11:19 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
That's why you're supposed to put pieces of wood behind the ramps to keep them from sliding. Its never failed. I don't like ramps because I'm always scared I'll go up and over them But it hasn't happened yet, and won't if you're careful enough. Aside from that, I do like using ramps.
Old Jul 14, 2004 | 12:36 PM
ljnowell's Avatar
I agree with RB, I never liked ramps either. FOr two reasons, one they are in they way. You cant take the wheel off with them. The other reason is that I saw one collapse one time. Very scary.
Old Jul 14, 2004 | 01:22 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
ramps are scary, I usually either drive with two feet (faster braking) or jack the car up from the k member and then put the ramp under the tire and use it like a jack stand, reverse isn't so scary with them and it saves you from having to jack the car back up to remove the stands.
Old Jul 14, 2004 | 01:35 PM
CaysE's Avatar
Low profile aluminum jacks are your friend.
Old Jul 14, 2004 | 01:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive put my car on ramps once it was in the air but Ive never been able to drive up onto them both. You could turn the wheels and get one up possibly, that would be enough to change the oil but wouldent be too safe. With my bird I cant even get to the front of the K-member thedamn airdamn is too low.
Old Jul 14, 2004 | 02:35 PM
Air_Adam's Avatar
Thats what the extensions do... they make for (initially) a lower angle to drive up, so you don't scrape on them.
Old Jul 14, 2004 | 02:38 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
yea, in order for me to jack from the k member, i kinda have to come in on an angle from the front to avoid the air damn, which in turn makes throwing jack stands under there a bitch.... such is life.
Old Mar 12, 2005 | 09:45 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I am going to try
another solution to jacking the car up..
I am going to try to
transfer the load to a 2x4 or 2x6 by 1 or 2 feet in length
center the wood at the notch jacking point placing the wood
vertically under the GFX.
for extra piece of mind while under I will take off the tires
and place them under the car just in case .
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
someone972
Aug 30, 2015 12:52 AM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
