need help with cam swap. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 15, 2001 | 01:56 PM
spitfire350's Avatar
Well i have an 87 camaro with a reman centerbolt 350 and i wanted to know if i can put flat lifters in the block machined for roller. And also what is a good way to change vlave springs, without pulling the heads. one more thing what is the process for wireing up a vaccume advance dist. in place of the comp controled one?
sorry for asking so many questions, but i appreciate all the help yall give me.
keep the stang's far behind u and the cops even farther
Old Apr 15, 2001 | 05:27 PM
ede's Avatar
ede
you can use a replace the hydrolic roller wiht a solid or hydrolic cam and lifters, just have to change push rods too. you can buy spring compresser made for head on engine applications. you use compressed air and a adapter to keep the valves from falling in the engine. i've done the distributor swap but don't remember the wires or how i did it.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Jorlain
Oct 8, 2015 01:57 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
masonta
Sep 1, 2015 06:40 PM
