Ticking Noise
Old Jul 13, 2004 | 08:13 PM
ryguy85's Avatar
Car: 1985 Z28
Ticking Noise
I just purchased my first camaro its an 85 with a swapped in 350 holley double pumper beefy cam (not sure of the durations) weiand intake. But when i start it up i notice a ticking on the drivers side of the engine, it doesnt tick on the passenger side, now i checked the engine over and i was making sure the rocker arms were all nice and snug not loose or anythign is there a possibilty that i over tightened. When it idles sometimes with will jump from 1000 to 750 i dunno if this is normal but its a fair amount of shaking but i thought that might just be from the engine. Any help or suggestions would be awesume. And also if anyone has a holley 700 double pumper i was just trying to figure out all the screws like idle and all of those if you have a pic and can show me thatd be great to.
Thanks everyone in advance
Old Jul 13, 2004 | 08:58 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
it could be a small exaust leak
Old Jul 13, 2004 | 09:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Ticking Noise
did you just tighten them up or did you set the valve lash correctly ..???
to set it correctly while the engine is running start the engine and loosen the rocker til it ticks then tighten it till it stops ticking and then go another 1/2 turn should be fine .....but with the engine running and the valve cover off its gonna spray some oil out at you ...if you go to the parts store and ask for some rocker stoppers they have them there pretty cheap and they stop the oil from flying out every where http://store.summitracing.com/defaul...+clips&x=0&y=0
Old Aug 15, 2004 | 05:07 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
lol funny I just asked the same thing on T3G. Hehe and the same person replied. Thanks for the info, but I'm still wondering if thats just a beefy cammed engine thing.....cause mine is new
cheers ya'll
Old Aug 15, 2004 | 07:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Bottom line: hydraulic lifters are not designed to tick. There may be rocker arm chatter, however, that doesn't sound like a tick/exhaust leak. Get that thought of "oh big cam, must tick" out of your head
Try resetting the valve lash.
Old Aug 15, 2004 | 07:36 PM
x_wolf's Avatar
Car: 91 Camaro RS
Ok so its not a lifter adjustment, so what?? rocker arm?
cornfused....
thanks
Old Aug 15, 2004 | 07:38 PM
JeffC1500TBI's Avatar
I know when I first had my engine built I had a ticking sound on the pass side.. turned out to be the rocker slightly hitting the valve cover.
Old Aug 15, 2004 | 09:11 PM
ljnowell's Avatar
Some valvetrains are noiser than others. I know that I can hear my roller rockers when it is running, but they dont tick, they make thier own noise. BOttom line is when you hear a tick, its not right.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
