Broken bolt related issue
Old Jul 13, 2004 | 08:24 PM
vortech305's Avatar
Now i know this tech boards, but my issue pertains to my clutch on my camaro. I had my torque wrench set at 20 ft lbs of torque for the clutch bolts to the flywheel. I've done this millions of times and happen to **** up on this one. I did the usual criss cross pattern. Every bolt is at 20 ft lbs, while attempting the last one it seemed to go above, me being the idiot i decided to keep going since there still was thread on the bolt and it snapped. So while every other bolt is held securely, one bolt happen to break off. My question is can i drive the camaro with one bolt off? I know the the obvious would be to do it all over again, but i have little to no time to do it all over again. I do plan on doing a T-56 conversion sometime next year, but was wondering if this will last me till then? Engine is slightly modded and i do run in the 5k rpm range. Will it grab sufficiently or am i gonna have issues.
thanks for any response.
Old Jul 13, 2004 | 08:33 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Which bolt broke?
I'm not clear on this:
"of torque for the clutch bolts to the flywheel."
Is it the flywheel to crank bolts or some other bolts?
I imagine if the others hold tight you'll be all right, but if they loosen and begine chucking, that will cause some trouble-
S-D
Old Jul 14, 2004 | 06:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The clutch will be warped, from spring pressure bending it up away from the flywheel. So it won't work right.
THat whole assembly is spinning around at 6000 RPM or whatever, about 4" from your right ankle whole you're driving the car. Hmmmmm.....
I personally would not leave it like that; but then, I'm rather fond of having feet. You may not like yours as much as I like mine, I can't say; but I'm sure I'm not ready to give mine up just yet.
I'd strongly suggest doing it right; get a set of actual clutch bolts from Mr Gasket or something, they're less than $10 a set; and continue to enjoy the benefits of feet. Some risks just aren't worth taking.
Old Jul 14, 2004 | 10:23 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
So RB, I can't call you stumpy any time soon huh?
Old Jul 14, 2004 | 11:25 AM
ede's Avatar
ede
RD sure you can but it has nothing to do with his feet
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
86IROC112
Aug 21, 2015 07:20 PM
Fronzizzle
Aug 9, 2015 01:15 PM
