Why is my car so slow all of a sudden
Old Apr 15, 2001 | 08:32 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
The other day my car all of a sudden got real slow. It still has decent torque and idles well but it has absolutely no horsepower. It struggles to hit 5000rpm in 1st gear. What could this be? It think it's the cat, because I cut the belt for the air pump about 1 week ago, plus it rattles at idle.
What would be the best route to fix this? Should I cut it off myself and have a shop weld me in a pipe. Should I buy a high flow one? I want the cheapest route, this car is a stock daily driver. Will it make the car louder without the cat?
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
Old Apr 15, 2001 | 09:25 PM
ede's Avatar
ede
i'd check for a pluged cat first.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 15, 2001 | 11:14 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
How do you check for a plugged cat? Could it possibly be a ignition problem?
1986 CAMARO Z28 ->
1987 TRANS AM ->
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
zeitghaist
Aug 18, 2015 07:33 AM
86Base
Aug 8, 2015 01:34 PM
