idling high
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
idling high
My engine idles fine (around 750) for about 15 minutes or so. It'll then go up to 1500. Also, if i'm sitting there and i rev it a little, when the RPM's come down it seems to stop around 2000. What is causing this? The only thing ive done is change my oil and take off my open element to check the filter.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
we need a little more info on your car does it have a carb or tbi or tpi ...what size engine is in it ????????
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you damage the IAT sensor when removing your open element. Did you distrupt the TBi unit at all. It sounds like you may want to check for vacuum leaks. Make sure the TBI is not leaking at the manifold base and check all of the vacuum lines that run the TBI unit. There are 5 of them. If one of them split or came loose your problem could be associated with that.
i figured it was his car he was talking about in his sig but you never know
Car: 91 Camaro RS
Engine: 305 TBI
i'll check those. thanks for the quick replies. Just for assurance in case it keeps up, other than hurt my gas mileage its not gonna do any damage is it?
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS
Engine: 305 TBI
It just started that day. I looked at the throttle control amd its not sticking, so it has to be something with the fuel injectors. I checked the vacuum lines and dint notice any leaks. As far as the IAT, how can I check to see if it is damaged?
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS
Engine: 305 TBI
well the old one was looking pretty bad, so i just went out and bought a new one. Didnt help. When i took it back out, i noticed the pintle was able to slide back in, and the spring wasnt pushing it back out. could that be causing the problem? How exactly does the IAC work? What else could be causing the throttle to stick open? It's starting to get annoying when i push in the clutch and the rpms will jump up instead of go down.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
