Retrofitting in place of a hydralic flat tappet cam.
Old Apr 13, 2001 | 03:43 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I currently have a Hydralic flat tappet cam.
(second blue one down)
http://www.compcams.com/catalog/064_065.html
Is there any way to use a roller cam like the Lt4 hot cam with hydralic non-roller lifters? I am thinking no? I want something with specs near the hot cam. Maybe slightly less lift, but summit only is showing roller cams. I don't feel like paying a ton for retro-fit lifters. I guess I will call comp or someone and get one made.
Old Apr 13, 2001 | 06:24 AM
ede's Avatar
ede
if you run a hydrolic roller you need roller lifter. if money is a problem wait untill you have enough, or buy it a piece at a time untill you can do the swap. if you have a non roller block you can't run a hydroilc roller anyway. you can run an aftermarket roller like we've been doing for 40 years or so.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 13, 2001 | 08:47 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
If you are talking about a 91 RS, then you have a roller cam.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Apr 15, 2001 | 05:34 PM
Aaron91RS's Avatar
Car: RS
<font face="Verdana, Arial" size="2">Originally posted by TransamGTA350:
</font>
I'm not. Almost every cam in Summit is roller grrrr. There is no way I am paying a ton to retro fit either.
Old Apr 15, 2001 | 06:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No you can't put flat tappets on a cam designed for roller lifters. It won't fly.
There are alot of flat tappet cams around, a whole lot more than there are of roller ones. If you want a flat cam with somewhat similar specs to the LT4 one, try a Comp XE268H, which is IIRC 224°/230° at just under .500" of lift, which is about as much lift as you'll be able to do with a street design flat tappet with that little duration. It's a real popular cam; I'm sure they'll be able to go right to it in the catalog, and have it in stock.
ICON Motorsports
Old Apr 15, 2001 | 10:56 PM
Aaron91RS's Avatar
Car: RS
The xe268 is a pretty good choice. I just feel I am losing power on the low lift numbers. This will be mated with trick flow twisted wedge heads heads which can flow good numbers at 500 lift. It's also on a 383 so off the line torque really isn't a big concern. On the other hand I don't want my max HP shifted up to 6500rpm's which the 274 will do. 110LSA isn't liveable either. What does a custom groud cam cost?
Old Apr 16, 2001 | 09:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Comp used to charge $25. It's been a long time since I was in the business of regularly doing that though. Call them and see, their # is 901-795-2400. Lunati, Ultradyne, and others will also do that for you. Both of those companies are also in the Memphis area (901), I can't recall their #s off the top of my head.
If you want more lift, use 1.6 rockers in addition to whatever you can get the cam ground to. Be aware that others on this BBS have had trouble with the springs that come on those heads at lifts above .525" or so. I fyou get past that I'd urge you to replace them.
ICON Motorsports
[This message has been edited by RB83L69 (edited April 16, 2001).]
Old Apr 17, 2001 | 12:34 AM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
IF YOU ARE RUNNING A HYDRAULIC CAM, MAYBE THE COMP CAM ONE YOU WANT IS #12-404-4 ( 268AH-14 ). SPECS ARE 222-226 (268-276) LIFT 464-464 WITH LSA 114. I RAN IT ON DESKTOP DYNO USING THESE INPUTS:
383 CUBIC INCHES
9.5 CR
HEAD FLOW NUMBERS FROM DART IRON EAGLE 215
LARGE TUBE HEADERS WITH MUFFLERS
TPI INDUCTION WITH 660 CFM INPUT
TIMING AT +4 DEGREES
I ALSO RAN THE NEXT CAM DOWN, THE 12-402-4 (260AH-14) WITH SPECS 212-218 (260-268) LIFT 444-444 WITH 114 LSA SO YOU COULD SEE THE COMPAIRSON.
COL 1 IS THE SMALLER CAM
TORQUE
2000 427 403
2500 432 415
3000 431 417
3500 431 424
4000 420 422
4500 394 403
5000 351 371
5500 300 324
MAX HORSEPOWER
LITTLE CAM 337 @ 4500
BIG CAM 353 @ 5000
HERS 90 IROC-Z 350 TPI
HIS 86 TRANSAM 305 TPI (406 AT SHOP NOW)
ZEEYAA
Apr 16, 2023 08:29 PM
Pac J
May 17, 2020 10:44 AM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
skinny z
Oct 5, 2015 06:23 PM
tattmann
Sep 27, 2015 05:20 PM
