ICM keeps dying
Old Jul 17, 2004 | 11:50 AM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
ICM keeps dying
I keep frying my ignition control module. The first time I had a shop repair it, and it fried in 2 weeks (Wells brand). I then replaced it myself, and now that one has fried after 4 weeks (GP Sorensen brand).
The shop-installed ICM gave me trouble whenever the car had been sitting overnight. The ICM I installed never had such a problem--but it did die after sitting for only an hour in the parking lot.
I have had no problems with it on the road--once the car starts, it runs strong.
The cap, rotor, wires and coil (MSD GM Blaster) have all been replaced in the past month. The pickup coil and plugs were replaced last year. The ICM I installed used the clear di-electric grease that came in the package.
I've done a search and seems the only other guy with this problem found out it was his alternator being stuck on charge. Is there an easy way to test this? (I don't have a multi-meter.) Any other ideas? I can live with all the other problems my Camaro has, but this one has me looking at the classifieds.
Old Jul 17, 2004 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Have you been coating the mounting surface of the modules with the heat sink compound they supply?
Old Jul 18, 2004 | 07:10 PM
Car: 1991 Camaro RS
yep. Nice thick layer of the clear grease
Old Jul 18, 2004 | 07:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take the car to an auto parts store and have them test the alternator both on the car and off the car. BTW, did this problem start after you put the MSD Blaster in. Also, have you had the ignition modules that supposedly went south tested?
Old Jul 19, 2004 | 04:51 PM
Car: 1991 Camaro RS
No, the original ICM just up and died one morning. I put in the MSD Blaster after the first replacement died. I haven't had any of the modules tested. I'll do that next (hopefully not) time. I never really bothered to do it, since as soon as I replace the ICM, the car starts right up.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
