Need Help With Timing Please...
Old Jul 19, 2004 | 05:51 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
well i went to make sure my timing was good on my 84 TA and i can't....in the haynes manual it says to disconnect the EST connector...well i can't find mine, when i search the forums i found some pics of it on the pass side by the firewall/fender corner, but in the book it says it's by the brake booster...i can't find this connector in either spot. the only connector i can find is my ECM power connector...so i don't unplug anything and try and i can't see the mark for the timing, i even marked the line with white paint....so can someone please help me out here???
BTW it's 84 TA L69 if that matters
Thank you.
Old Jul 19, 2004 | 07:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you want to set it to the "spec", you need to disconnect the 4-wire Weatherpak connector that hangs down out of the bottom of the dist at the back. Then start the car up, set it, turn the car off, and plug it back in.
Then when you realize your car probably doesn't run as good as it did before, you'll probably want to set it to where the car runs the best, which will usually be somewhere somewhat advanced from the stock setting.
Old Jul 19, 2004 | 10:52 PM
chio987's Avatar
Engine: 305 4bbl HO
ok, well if the stock setting sucks then what should it be set to, how would i tell if it's right or not??
Old Jul 20, 2004 | 06:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Shouldn't be too hard to spot.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
