MPG For A 1982 T/A With Carb
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
What kind of gas mileage did these get stock?
I have a brand new 305 With the CC-QJet
Im going to be driving cross country and would like to make some rough numbers on gas Exspenses.
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
according to www.fueleconomy.org
and 85 gets 16/22 the only reason i put a 85 is cause they don't go back to 82. I would imagine it is going to be right in there. It might be more or less. I do know that if you do 55 you get optimal MPG. Check out that site, it should be helpful. With the cost of gas I would just invest in a geo metro
instead of paying for gas in your bird. It would probably come out close considering the great gas mileage they get.
instead of paying for gas in your bird. It would probably come out close considering the great gas mileage they get. TGO Supporter
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will be a little less, because IIRC, '82 did not have the OD transmissions like '83-92 did.
They just had the 3 speed auto, and 4 speed manual, all with final gears of 1:1.
Car: 4
Engine: 6
Transmission: 5
82s didn't have the 200-4R. They had the 200C..... lockup clutch but no OD.
In any case, when new, they should have done around 20 mpg on the highway. If it's important to you to get close to its actual fuel usage in its current condition, which may or may not be similar to original, I'd recommend filling it up at a freeway exit, driving it about 20 miles (like 10 miles one way, turn around at an exit, and come back), then filling it up again; and seeing how much it used.
sreZ28
Oct 22, 2015 08:21 AM
