1990 trans -am 5.0
Old Jul 19, 2004 | 06:22 PM
gold0_9's Avatar
Car: trans-am
Engine: 305 tpi
1990 trans -am 5.0
can you guys please tell me what other engines ( with least
possible problems ) that could easily droped in, or should i just
get the same 305 tpi. thanks .
Old Jul 19, 2004 | 06:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Any small block chevy will fit. As far as problems are concerned that depends on what you mean. Some concerns would be blocks with 2 piece real main seals (which use different flexplates/flywheels), different valve cover bolt patterns (parameter vs. centerbolt), intake bolt pattern (not too much of a problem since you can just elongate the center holes with a drill), or older heads which lack assessory holes. All will bolt in however. The main concern would be power level. Once you are making considerably more power you need to worry about everything in back of the engine like the tranny, rear diff etc.
Old Jul 19, 2004 | 07:29 PM
gold0_9's Avatar
Car: trans-am
Engine: 305 tpi
1990 t/a 305
i have a chance to buy a ( 1990 chevy pick-up 305 ) will this be fine.
Old Jul 19, 2004 | 09:35 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No you don't want that. Its the worst of the worst!!! Why don't you get a 350.
Old Jul 20, 2004 | 01:55 PM
gold0_9's Avatar
Car: trans-am
Engine: 305 tpi
305 strong no power.
well my 305 is strong but it , its codeing 45 and i put a new 02
sensor on, map, temperature, cleaned egr, cap, rotor. wires,
plugs, checked timming, vacume, oh and fuel filter. i also checked
fuel presure. it surges and bogs down when i try to pass. at a
stand still, you stomp it, it won't spin tires. it is a 1990 t/a speed-
density, no maf sensor. now i let a mechanic i know give it a try.
he says #8 plug is fileing out, and thinks its either, valves or
injecter. if so will new heads cure this, and can i use 350 heads.
thanks.
Old Jul 20, 2004 | 03:56 PM
89RsPower!'s Avatar
whats fouling the plug? Oil? gas? your going to replace the engine due to a fouling plug?
Old Jul 20, 2004 | 04:12 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well if you are doing the work yourself, the cheapest thing to do is pull the heads and get the valve work done. The heads on that 305tpi are casting #081. They are some of the best stock 305 heads out there. A little porting work while you have them off would be good also.
As far as the 350 heads, you can use them but they will need to be milled down pretty good or your compression will be super low. (Atleast from what I have read, this is not an area I know anything about).
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
