Valve cover hole hose fitting?
Old Jul 21, 2004 | 04:04 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I want to connect a hose to the hole in my valve cover (1.25" diam) the hose should be large, around 1.25" diameter like the hole in the cover........
Anyone knows any part nbr/size for a 90 deg fitting I could use? Will order from summit..............
This AN and NPT stuff is very confusing we only use metric system in sweden........
/N.
Old Jul 21, 2004 | 10:44 PM
ede's Avatar
ede
what you'd want is a grommet. a rubber bushing the od would fit the hole in the valve cover and the id would fit your hose. you wouldn't use a hose the same size as the hole in the valve cover.
Old Jul 21, 2004 | 10:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What's this hose for?
Summit sells both regular and baffled grommets (for use with breathers).
<A HREF="http://store.summitracing.com/partdetail.asp?part=SUM-G3411&N=120%20300038">Regular grommet for PCV valves</A>
The only grommets for the valve cover size you will find advertised at summit are the PCV/breather kind. You could probably call them and try to find something else if that is not what you need.
Old Jul 22, 2004 | 06:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Ok, but I want a 90 deg elbow to any part nbr on that? earl/aeroquip?
Old Jul 22, 2004 | 10:34 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What is this hose for? What purpose does it serve? Most of the time, when something gets plugged into the valve cover it is either an oil fill cap or part of the crankcase evap system.
Old Jul 23, 2004 | 06:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Just a hose to a breather catch can.....
/N.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
