I can use this block right???
Old Apr 19, 2001 | 12:23 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm picking up a 4-bolt main truck block on monday that was a factory roller cam block and has a one-piece rear main seal. This is totally interchangeable with the block that's currently in my 89 IROC-Z right?
Old Apr 19, 2001 | 12:40 PM
89BlwnRs's Avatar
Yes it should be a direct swap as far as the block goes.
Jason
Old Apr 19, 2001 | 01:06 PM
Car: 89 IROC-Z
Engine: 383
Sensor ports and accessory bracket holes and all right?
Old Apr 19, 2001 | 02:51 PM
89BlwnRs's Avatar
Yes, the oil pressure and knock sensor ports should still be there, but if you're going from a 305 to a 350 you'll need a different knock sensor. The bracket holes should be there too.
The Gen II small blocks are the same except for the bore offered.
Jason
Old Apr 19, 2001 | 03:22 PM
Car: 89 IROC-Z
Engine: 383
Thanks. I already got my 350 knock sensor so I should be set as long as I don't put a hole in this block too.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old Apr 19, 2001 | 07:20 PM
Joseph@SDSC's Avatar
That one looks great Paul.
<font face="Verdana, Arial" size="2">The Gen II small blocks are the same except for the bore offered</font>
The GENII small blocks were of the LT1/LT4 designation (92-97) and there are actually a few differences, but the bore was the same except for the 4.3L V-8 (yes V-8) that was in a few Caprices that had a small bore.
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM ZZ4 intake manifold, ZZ4 roller camshaft)
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM ZZ4 Intake, Edelbrock 750, eventually will be Ram-Jet)
Old Apr 19, 2001 | 07:24 PM
CamaroZ_85's Avatar
there was also a 4.3 V8 back in the day, some guy tried to sell me an 81 cutlas or soemthin with one...what a dog...i believe it's a 262 or something
Old Apr 19, 2001 | 08:07 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
It was a 267...Kevin
Old Apr 19, 2001 | 08:47 PM
89BlwnRs's Avatar
Sorry, by Gen II I meant the new 87+ roller blocks w/ 1 piece rear main seals. I know the Gen IIIs are the new LS1 blocks, and I guess I forgot that Gen IIs are LT1 blocks.
When I said Gen II I meant the new 87+ roller blocks w/ 1 piece rear mains.
Sorry for the confusion,
Jason
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
