Oil pressure woes......
Old Apr 19, 2001 | 08:37 PM
matty350TPI's Avatar
Ok I'll be driving and the oil pressure will go way down then come back up after a few seconds. Sometimes longer than others. It seems to do it after I shift. I have heard about sender units going bad. Where is the sending unit so I can change/check it?
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Apr 19, 2001 | 09:51 PM
ede's Avatar
ede
your sender ought to be near the distributor. if you don't know what one looks like buy the replacement so you do ,and buy a socket to fit the sender.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
