Diesel Down
Diesel Down
I just got a 4.3L 262 Z motor from a 95 chevy truck. The problem is the motor diesels down when you kill it and smells like fuel for the first ten minutes. Also the guy that had the truck said it got about 6 mpg on the highway. Timing is set at 0 and wonder what else the problem could be. Motor was free!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What does it have on it (CPI? TBI?). I dont remember what the code was for each of the induction systems. If its got CPI or whatever they called it then theres your problem right there... Leaking fuel and carbon deposits will enable it to diesel after you shut it down.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Is this 3rd gen related? If not this will get locked. Just a hint.
Anywhoo, dieseling can be assocaited with the following,
Idle speed to high
Improper timing
Exsessive engine temp due to malfuncioning t-stat, clogged radiator or faulty water pump
Idle speed to high
Improper timing
Car: 88 Camaro SC
Engine: SFI'd 350
Once the engine is shut down there shouldnt be any fuel available for the motor to diesel on other then what remains in the manifold after shutdown. Turn the key to the 'ON' position several times after shutting off each time for more then 5 secs. to prime the fuel system and check around the injector pod to see if its leaking fuel from anywhere.
EDIT: If all that looks good then check the above.
Car: '90 RS
Engine: 377 LSX
Originally posted by getusmonster
new water pump, and just flushed radiator. Could be t-stat though. And yes this is 3rd gen related. Have blue cam. with a 305 in it now only i use it as a pizza delivery car. gas mileage sucks.
Car: 88 Camaro SC
Engine: SFI'd 350
I guess if its a 4.3 in a thirdgen then its at least quasi-thirgen related. The fact that you smell fuel is one clue. Have you checked for fuel leaks yet? If it only diesels for a second or so then it may not be related but if it carries on for a bit then there has to be something thats supplying it fuel. Unlike a carb, once the key is turned to the off position, there shouldnt be any more fuel available for the engine to run off of.
school boy
Oct 22, 2015 11:47 AM
MoonDog
Jun 14, 2002 12:37 AM
86Trans Am
May 12, 2001 02:10 AM
