Buzzing sound and EGR error code
Old Jul 23, 2004 | 05:26 PM
Ardels91TA's Avatar
Last week after driving my 91TPI TA for about an hour, the SES light came on. I checked it out, and it geve me the EGR system code. ANy ideas what I should check first to see what is wrong? Secondly, there is a buzzing sound coming from the engine, it sounds like its from the back, or middle of the plenum, most noteably heard on the passenger side. I can't tell if its distributer, electrical, or maybe EGR, given that I got that code. It seems to only buzz when up to normal operating temp. Just thought I'd see if anyone might have a shot in the dark answer to my buzzing problem. I know its kinda vague, bu I thought I'd try. THanks
Old Jul 23, 2004 | 08:31 PM
Vader's Avatar
I'd suggest a close inspection of the EGR solenoid, its wiring, and the grounds. That may solve both the noise and error code.
Old Jul 23, 2004 | 10:11 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've had ignition coils that "buzzed" before.
Old Jul 24, 2004 | 02:19 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I guess that buzzing/noise could be from a blown EGR diaphragm.
Old Jul 24, 2004 | 04:42 PM
Vader's Avatar
Good point. If you were to catch the noise when the EGR solenoid was modulating vacuum to the valve, AND the valve pilot was closed, a perforated or torn EGR main diaphragm might buzz. Of course, none of that should happen at idle.
Old Jul 24, 2004 | 06:13 PM
Ardels91TA's Avatar
Thanks guys, I figured someone would have some good idears. I'll check it out and let you know what I found.
Lanz06
Sep 14, 2015 07:16 PM
Blue419
Sep 10, 2015 01:03 PM
64goatman
Sep 9, 2015 01:09 PM
rjcme
Sep 5, 2015 01:23 PM
RyanJB
Sep 2, 2015 01:27 PM
