Speedometer swap
Old Jul 23, 2004 | 11:18 PM
puckboss3's Avatar
Car: 1984 Camaro Z28
Engine: base crate 350, new GM
Speedometer swap
i have an 84 z28 with the stock 85 mph speedometer. does anyone know if i can buy a speedometer with a higher max mph (not that i plan on goin faster than 85, he he ) to directly replace my stock one in my dash.
p.s. - i know there are external speedometers that i can buy, but i am looking for a direct replacement for the stock one with a higher max mph.
thanx
Old Jul 24, 2004 | 12:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only thing that will replace a stock speedometer is another stock speedometer. Twenty years ago when these cars were new and the fastest speedo you could get was 85 mph, there were aftermarket ones available that turn up now and then, but they're too rare to worry about.
Old Jul 24, 2004 | 12:43 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You should be able to swap in a 120MPH or 145MPH guage...
Old Jul 24, 2004 | 12:48 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I swapped a 120mph into my original 85mph car no problem. Simple replacement. The hardest part will be finding one to swap.
Old Jul 24, 2004 | 12:51 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Shouldn't be too hard to find one, they turn up on eBay all the time.
Old Jul 24, 2004 | 07:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a 110 speedo cluster. Should you be interested, please PM me.
JamesC
Old Jul 24, 2004 | 07:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a 145 mph one out of about a 87 or so IROC. Direct swap-in. Requires that you use the 87 bezel, because the trip odometer reset stalk comes out in a different place. Takes about 10 minutes to swap if you stop for a cold one halfway through.
Old Jul 24, 2004 | 11:37 AM
puckboss3's Avatar
so i am gathering the instrument cluster on pretty much all the third gens are the same shape and size for an easy swap in and out...
Old Jul 24, 2004 | 02:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Anything from an 82 to 90 Camaro will fit, but in 1988 the locations of some of the warning lights changed after they stopped making carbed cars. The location of the trip odometer reset changed like RB83L69 mentions too. In 1991 the dash changed significantly and Camaros got electronic speedometers. Firebird dashes are entirely different.
Old Jul 26, 2004 | 02:29 PM
puckboss3's Avatar
thanks for the info guys...
Old Aug 6, 2005 | 10:00 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
By any chance, will a speedo from a transam fit a Camaro? Specifically, will a speedo from a 82 Transam fit a 84 Camaro? Thanks.
Old Aug 8, 2005 | 11:01 AM
puckboss3's Avatar
I believe my speedometer has a 5 inch diameter. So as long as it is the same size, and requires the mechanical speedometer cable to operate, it should fit.
Old Aug 8, 2005 | 01:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know that the Camaro and Firebird speedometers are mounted into the gauge clusters in the same way.
Old Aug 8, 2005 | 02:45 PM
I dont think that they are mounted the same as in the clusterbut I was wondering if the guage itself could be taken from the Transam and changed to the Camaro. I thought that if all I need was the guage , then all I would have to do is remove and reinstall it to the Camaro. Trouble is, I dont have the Transam nearby to confirm. Would probably need to measure and make sure the screws line up. Anyone have both to compare? As far as I know no one has talked about this sort of switch.
Old Aug 8, 2005 | 05:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How are you going to mount it then?
Old Aug 9, 2005 | 02:10 AM
Cant the guage itself be taken out of its transam cluster and installed in the camaro cluster? Thats what I was getting to. If they are the same size then you should be able to transfer them into another cluster. I cant believe that GM would make two different sized guages.
Old Aug 9, 2005 | 11:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Only if the mounting holes are the same. The Camaro and Firebird clusters are entirely different, so I wouldn't count on it.
Old Aug 9, 2005 | 12:18 PM
JamesC's Avatar
Check the following link to see the back side of the Camaro cluster, which may provide you with some info (but I'm with Aperion: I doubt that the TransAm cluster will fit):
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Eric2ndGen
Nov 5, 2015 01:51 PM
AUZ28
Oct 12, 2015 08:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
