Quick help needed
Old Jul 25, 2004 | 12:30 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Quick help needed
Hey guys. I have an 84 Trans Am with an LG4 (305 4bbl) out of an 87 Trans Am in it. The other day at my girlfriend's house, it wouldnt start. I checked, and no spark. Had it towed home, tested the ignition module, it was bad. So while in there, I replaced the module, coil, cap, and rotor. Now I am getting spark, and I can see fuel being pumped into the carb. Firing order is right on the cap. The thing will not start, not even with starting fluid. I also just replaced the starter. Any ideas on what to check? Could my timing be way off for some reason? Thanks.
Brian
Old Jul 25, 2004 | 12:42 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
are you positive the fireing order is correct i know ive seen quite a few people start one wire off on the terminal ......i dont see how the timing could be off unless you loosened the distributor ....hmmmm
Old Jul 25, 2004 | 01:16 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Positive. Did not loosen the distributor at all for any reason. I have enen tried moving the wires on the cap one spot in each direction, no luck.
Brian
Old Jul 25, 2004 | 06:41 AM
ede's Avatar
ede
spark, fuel, compression are all you need for it to run. if you're sure you have all 3 then you need to start checking if it's in the right amount and at the right time. i'd suspect you have messed soemthing up making your repairs.
Old Jul 25, 2004 | 07:37 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
had the same problem a while back with my new 355.
the cylinders are probably soaked with gasoline, get all the sparkplugs out, and leave them out for a night.
that way the cylinders are dry again, reinstall the sparkplugs and away you go!
it sounds a bit easy, but i promise you that is the problem!!!
Old Jul 25, 2004 | 03:22 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Ok, home from work for lunch for now, will take out the plugs and let it sit, see what happens. Any other ideas for me to try? This is really driving me nuts since I have everything i need for it to fire, and it wont! Grr ....
Old Jul 27, 2004 | 02:28 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Well found my problem. No compression in Cylinders 1 and 3. Probably means no compression in 5 and 7 either. Which probably means ..... blown head gasket? Last time I go to Performance Clinic ....
Infested
May 22, 2018 11:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
