carb vs fuel injected?
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
im stupid.
are there any benefits of a carburated engine?
is a fuel injected one better?
i don't really know anything, so whats the difference.
Car: 4
Engine: 6
Transmission: 5
It's typically much easier and far cheaper to get more power out of a carb compared to FI; subject of course to the rest of the engine, and the purpose at hand.
FI typically gets a little better gas mileage and potentially alot lower emissions than a carb; but is much more difficult to tune to an engine set up for racing.
If you already have a car set up for the one, IMHO it's best to use it, rather than trying to hack the other in. Unless you have a whole donor car to get all the little detail things that are different; starting with the gas tank and fuel lines.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: carb vs fuel injected?
Originally posted by Airpak
im stupid.
im stupid.
The are many types of FI (fuel injection). Some are similar to carb (TBI) and others implement direct injection of fuel into either the port of the intake manifold runer (port injection like TPI,LT1, LS1) or into the cylinder head (direct cylinder head injection found on some newer nessans). A computer determins the amount of fuel required based on throttle position, engine load, AF ratio, and engine speed. The computer gets this data through a series of sensors that provide feed back to the computer.
Carb is a more simplistic system that can support large power numbers. However, it cannot touch the fuel managemnt, and emissions reduction capabilites that a FI system can meet because it is stickly a non-feedback system (it can't make corrections). Todays FI is far superior to most carb set-ups out there. It comes at an expense though. FI gives you the ability to change a whole slew of parameters throughout the powerband to support all kinds of engine combos. That is why you can have a 346ci LS1 making 500 at the crank while still holding a smooth idle and getting 20+ mpg. You won't see that with a carb.
Hope this helps a little.
yeah i get like 13 mpg with my 350 =P
i dont really mind though. so what kind of advantages or things can i do to pump out the most power with my carbed engine?
its street driven, but not daily, its more occasional.. it probably wont be a track car either, since we have no track here =P n the closest one if probably a few hundred kms away.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Car: '90 RS
Engine: 377 LSX
Originally posted by ME Leigh
Thats not why, but i know what you mean.
Glad you catch my drift. Thread Starter
what would be the most important performance enhancers for a carbed 350?
i should have a few grand (canadian) left this summer, and i'd like to do things myself, but right now i dont know much. i should probably find a dyno though, because im sure im pumping out quite a few horses right now.
Car: '90 RS
Engine: 377 LSX
Car: 1985 Firebird
Engine: 327
Transmission: TH350
Re: Re: carb vs fuel injected?
Originally posted by ShiftyCapone
A carb is a mechanical devise that lets an amount of fuel in for a certian amount air. Basic physics and thermodynamics makes it happen.
Car: '90 RS
Engine: 377 LSX
Originally posted by five7kid
Phase change of the fuel, fuel/air mixing, etc.
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
