engine idle
Old Jul 28, 2004 | 08:28 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
engine idle
why does my motor act like its gonna die when i put in drive???
350, edel intake,carb,mallory ign,no computer works,all mechanical, help!!
Old Jul 28, 2004 | 09:50 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
do you have a vacume leak ?
or you could just need to set up your idle a little
Old Jul 30, 2004 | 02:50 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Re: engine idle
First, make sure your idle speed is high enough that when you put it in gear the engine stays strong.
Second, check the manifold, carb, and vaccum lines for leaks.
Third, check your timing and ignition- a poorly tuned ignition makes a car really weak.
Old Jul 31, 2004 | 09:41 AM
Vader's Avatar
Well, he DID say he has a carburetor... Doesn't that qualify?
Old Jul 31, 2004 | 11:15 AM
THEGENERAL's Avatar
LOL
Old Aug 2, 2004 | 06:16 AM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
i adjusted my timing with a light to 0 ,not good did it by ear aand it made a world of difference runs like a striped assed ape until i run for about a half hour then it wants to die,at stop. no leaks, is it possible that the gas in the line is getting to hot? it ran at 220 id guess but the temp line is running between my headers anyway i got a 160 stat and it keeps it a little cooler but this idle thing is making me nuts
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
