Anyone achieved this?
Old Apr 20, 2001 | 12:25 AM
gwman's Avatar
Has anyone been able to keep the engine temp under say 220 when driving in rush hour traffic in 100 degree weather with the A/C running full blast? I have tired but cant do it. The car goes from 180 to 220 in a matter of minutes.
Old Apr 20, 2001 | 07:47 AM
ede's Avatar
ede
yeah my iroc ran at 140 on the road and around 190 sitting. i guess i just got luckey because i never really did much to it. 160 t stat, hypertech fan switch, duel fans, cooling system was clean and radiator clear and in good condition.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 20, 2001 | 10:05 AM
Beefy89's Avatar
Mine runs like ede's about 140 on the highway and 190 sitting still.I've got a 160 stat and a Stewart stage 1 water pump.I'm going to put a 180 stat in it this weekend cause it's really eatin the gas.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 21, 2001 | 09:18 AM
dtpmike's Avatar
how does a t-stat effect gas mileage? I have a 160 one so im jsut curious?
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, and a 160 degree T-stat. 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from [URL=http://www.MrMikes.com[/URL](its nice)
TES Headers in the mail, and about to order a stage 2 fastchip.
Old Apr 21, 2001 | 09:21 PM
Stell1579's Avatar
<font face="Verdana, Arial" size="2">Originally posted by gwman:
Has anyone been able to keep the engine temp under say 220 when driving in rush hour traffic in 100 degree weather with the A/C running full blast? I have tired but cant do it. The car goes from 180 to 220 in a matter of minutes. </font>
first off the factory thermostat is a 195*
you could change this to a lower temp depending on your aplication for non strip use i would say go with a 180*
now i asume it is electric fans. if so, check this article out on them. one of th emembers of this board wrote how they work stock and how you could mod them to run cooler.
https://www.thirdgen.org/newdesign/tech/cool.shtml
but a range of 190-220 or so is normal from the factory. what ever posesed them to make it run that hot, i dont know
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air, Hooker Aerochamber Catback,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
http://stell15790.tripod.com/cars.htm
Old Apr 21, 2001 | 10:53 PM
LottaBallsCamaro's Avatar
They did it in the intrest of emmisions. Its also a big reason our cars have iron heads.
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 21, 2001 | 11:20 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Mine runs in the 180* area when it is pretty hot out, and going down the road, then when stopped, it gets up to around 200*. This is with the A/C running.
The temperature readings are based on the stock temp. gauge which we all know isn't very accurate, but it does give you an idea of where you're running.
Oh, I almost forgot, that's with a 170* stat, and the dual electric fans with the hypertech 190* fan switch.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
[This message has been edited by JP84Z430HP (edited April 21, 2001).]
Old Apr 22, 2001 | 12:07 AM
UVA3rdGen's Avatar
ya, my car never breaks 140 according to the dash. Ofcoarse the dash gauge is off by about 40 degrees and i do not have a/c.
Old Apr 22, 2001 | 12:41 PM
gwman's Avatar
The problem I have is even with a 180 stat perma cool fans one 14" and one 10" and a 3 row radiator and a fan switch that kicks on at about 215 it still gradually gets up to 230-240 in traffic with the A/C running. The only thing I haven't done is a high flow water pump with a high flow 180 stat. Should this solve my problem? But is too much flow not good?
Old Apr 22, 2001 | 08:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
230-240 is cooking your engine, I would suggest finding where your temp. problem is soon.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
91L98Z28
Jan 26, 2002 05:08 PM
Little GTA
Dec 27, 2001 01:44 PM
Gta-Paladin
Dec 10, 2001 06:54 AM
